This command shows VRRP group status.
| group | Form a group of VRRP VRs to operate in high-scale mode. |
| group_name | Specifies the VRRP group name. |
None.
The following example shows VRRP group information for group "ExtremeNet":
show vrrp group ExtremeNet
Group Name: ExtremeNet Group Status : Enabled
Virtual Master
VLAN Name VRID Pri IP Address State MAC Address TP/TR/TV/P/T /FR
Primary-VR:
v1(En) 0001 225 100.0.0.100 MSTR 00:00:5e:00:01:01 0 0 0 Y 1 Y
Secondary-VR(s):
v10(En) 0001 225 100.10.0.100 MSTR 00:00:5e:00:01:01 0 0 0 N 40 Y
v11(En) 0001 200 100.11.0.100 MSTR 00:00:5e:00:01:01 0 0 0 N 40 Y
En-Enabled, Ds-Disabled, Pri-Priority, T-Advert Timer, P-Preempt,
TP-Tracked Pings, TR-Tracked Routes, TV-Tracked VLANs, FR- Fabric Routing
Total number of member VRs of group : 3
This command was first available in ExtremeXOS 22.2.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.1.1 Licensing Guide document.
